External Content - Troubleshooting guide
Tamas Gaspar
The External Content Menu is missing from the File menu in ARCHICAD 19 Solo edition
Affected version: 19 Solo | Severity: workaround applicable | ID: 200991
wp-content_uploads_2016_06_Info_18x18.png NOTE: This issue will be fixed in ARCHICAD 20 Solo.
Issue
The External Content menu is missing from the File menu therefore the Place External Drawing command and the Drawing Manager menu is also missing from the default Work Environment.
Solution
Workaround: The Drawing Manager can be accesed from the Navigator or the Organizer.
The Place External Drawing command can be placed in the File menu or any other menu through the Options - Work Envrionment - Menus dialog.
Updating placed External Drawing error message appears in ARCHICAD 19
Affected version: 19 | Severity: workaround applicable | 194681
wp-content_uploads_2016_06_Info_18x18.png NOTE:This issue was fixed in ARCHICAD 19 Update 4011.
Issue
When one would like to update a placed external drawing, or a layout which contains it, an error message appears:
Cause
A view - showing a placed drawing on a wireframe layer – is placed on a layout, and the view is active on the user-interface.
Solution
- Updating the drawing in layout view
- Set the layer to Solid view mode
Browse more articles
Back to articles
