Format Wizard - Manual List Schemes (bug)
In Archicad 17 (and other versions too) when you want to create custom
list scheme, when you start FORMAT WIZARD, Archicad is not able to save
custom layouts with PLN file. You are able to edit your custom layout via
FORMAT WIZARD as long as you don't turn off Archicad. No matter how
you save it...your custom lists will be lost from FORMAT WIZARD when you
close archicad...(try it)
Is there any way, some special work around to save list and to be able to
edit it after saving and exiting archicad.
I spent days trying to figure out how this graphic wizard works...After i
finally get it...i realise that i can't edit "tomorrow" my lists via graphic
wizard, only manually via text editor because AC can't edit external lists
(i don't understand why)
Nec
list schemes are saved in your library and not in the pln-file. So you can either get (write/change) access to your library Folder, which usually is inside the program files folder (as normal user you have restricted access) or you drag at least the 'list elements' folder outside the program files folder and add it in the library Manager.
