‎2019-10-21 08:10 PM
‎2020-08-19 11:51 AM
‎2020-08-19 05:26 PM
‎2020-08-19 06:11 PM
Tim wrote:That is my point. So much work for a simple task. And with this process I will have to create one Mesh for the Existent Terrain, another for the Proposed Terrain. And in case I change the Proposed Terrain I will have to redo the process of defining the excavation volume. If we could turn On and Off these SEO operations according to the documentation need, I could have just one Terrain Mesh in which I add or subtract geometries according to its visibility. Then a AddedVolume and SubtractedVolume (Similar to NetVolume and GrossVolume) on a schedule would give me the live data grading calculation.
Intersect the top of the slab to the mesh using SEO
Cut the mesh with the slab using SEO
Convert the resulting slab shape to a morph to fix the shape
Read the mesh morph
Classify and label the morph so you can share the data correctly
