How to apply wall builder from cadimage for angel wall
Hi I have a problem, when I use cadimage for wall builder ( to make a cladding wall) in my 80 degree angle wall, The cladding wouldn't follow the actual wall (still vertical 90 degree), can you guys solve my problem....?
4 REPLIES 4
Dwight
While someone with an actual fix might show up, my approach would be to make a complex profile wall with the cladding included.
Dwight Atkinson
Gerald Hoffman
As far as I know you can CadImage Wall accessories will not work on angled walls. Check with CadImage to make sure.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
Okay.. thank you guys...
Dwight
An example of siding partly covering a [praying] angel wall — complex profile, etc.
Dwight Atkinson
