How to get cadimage coverings to line up
How do I get the cadimage coverings (vertical timber) to line up over 2 floors?
Ive attached a picture
14 Replies 14
David Shorter
I don't have CADImage tools but I would expect Design/Align 3D Texture/Set Origin to work.
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
Or maybe invert the direction of one of the walls?
Depends which cladding you are using.
Panels has a horizontal offset you could use.
I find the easiest way set the origin of both claddings to one of the story setting as opposed to the bottom cnr of the wall. The setting is on the top right of the Main Covering page on the AC 20 version. Should line up then. Think it works of the drawing xyz then
I am using the shiplap (grooved) profile rotated 90°
How do i invert the direction of the wall??
I adjusted the offset from the origin by how much it was off by.
Edit > Reference line and plane > Invert wall direction.
Turn Wall and Beam Reference lines on temporarily in View > On-screen View Options if you want to see the result
Thankyou!!
Is there any way to offset Cadimage coverings horizontally? I want this cladding break to be centered above the window.
The only way I have found to do this is to set the reference origin to wall center. This, however, breaks the the vertical consistency with the adjacent wall...
Any ideas?
