davdelven
IFC 4 issue with Door type
IfcDoorStyle should be deprecated detract from IfcDoorType.
(http://www.buildingsmart-tech.org/ifc/IFC4/final/html/schema/ifcarchitecturedomain/lexical/ifcdoorst...)
Am I do something wrong with IFC2x4 Schema management in ArchiCAD 21 ?
Thanks mates.
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
8 Replies 8
felcunha
Hello David,
Do you mean IFC4, and what is your precise need ?
(if you prefer you can formulate your question also in Spanish, maybe I'll understand it better).
Felipe Ribeiro Cunha
AC 26, macOS Monterey
I will bring this to the attention of the IFC team at GS HQ.
davdelven
Thank you, Laszlo!
And Felipe Ribeiro Cunha, indeed, I mean IFC4 (or a.k.a. IFC2x4) schema release. English is already fine, here. Let the Spanish away in this forum 😉
Hi David,
I have received info from GS HQ. They said that information on the User Interface is coming from IFC2x3. For technical reasons they cannot continually switch UI elements based on the version of IFC selected, I am told.
However, when the actual IFC4 Export/Import occurs, it correctly works with IfcDoorType, and not with IfcDoorStyle as the IFC2x3-based UI suggests.
davdelven
Thank you, Laszlo!
Good to know about it. We hope there's some alignment update with IFC releases in UI, from time to time, to avoid some misunderstandings.
I will publish your answer on my professional network.
Hello
However, when the actual IFC4 Export/Import occurs, it correctly works with IfcDoorType, and not with IfcDoorStyle as the IFC2.3-based UI suggests.
That may work on IfcDoorType. What about IfcBuildingElementProxyType? PROVISIONFORVOID is possible in IFC 4. However, this cannot be selected in the type assignment of the IFC translator.
Thanks
Caspar
Caspar wrote:
Hello
Thanks
Caspar
I got the following info from the developers:
At the moment IFC4 can only be supported in "compatibility" mode, since IFC4 itself is still under certification.
However, there is a question for you:
Why do you need support of PROVISIONFORVOID for IFC4 export. This is an entity type that usually MEP programs generate (these Voids, I mean), and they are imported into ARCHICAD. So it is understandable in case of import, but why do you need it in case of export from ARCHICAD?
stefan
I was trying to export an IFC4 file with this type for the indication of openings to be coordinated. It is a recommended practise in the Dutch USO (Uniform Openings/Voids Specification).
As the internal scheme uses Ifc2x3 no IFC4 classes or types can be selected.
Archicad-user since 1998
my Archicad Book
