IFC exporting surfaces with Highlights affect looks white
When I export *.IFC, wall surfaces that receives more sun (Highlighted) becomes white, so model looks strange. Is it possible to turn off Highlight effect when exporting *.IFC ?
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v27 INT / NOR (5030)
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Algimantas,
Thank you for the report and I am sorry about the issue!
This is the first time I see such an issue with IFC export! I'm wondering which software you are using to read the IFC output? Do you see these brighter walls when reimporting the IFC back to Archicad? Furthermore, which Archicad version are you using?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
please, for hierarchical elements, is it possible to have a summary of the materials used? when using the simplified geometry of hierarchical elements option in the translator
AMD Ryzen 5950x
AMD RX 6750xt
AC27
