I think you expect an ifc for which it was not designed. The question is not how to achieve it with Archicad or any other software? The question is: is it an ifc designed to generate 2D deliverables as qualitative as Archicad's 100% dynamic 2D deliverables?
The answer to this question is NO
But maybe you can try to rough out the subject by tinkering with the parameters
An ifc =
- no quotes
- no annotation
- no texture in 3D
- no shadow
- a model that varies according to the reader for the same file
- no cut
- no plan
- no facade
- no nomenclature
An ifc that has all this is very easy to export because it is a BimX file only via Archicad for over 6 years
Christophe - FRANCEArchicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
