Ideal Structural Collaboration
smith74
I'm trying to figure out what I expect from the ideal structural collaboration process in ArchiCAD.
(I'm not even sure I could convince our structural designers to collaborate with us on a higher level.)
At the moment we always receive 2D drawings back from them (dwg) with a list of changes, what we manually apply to our ArchiCAD modell.
Are there others in the same situation?
I'm dreaming of the following:
-export the structure from ArchiCAD to a file
-send this file to the Structural company
-continue working on the Architectural model
-get back a file from the structural company
-compare the two models and decide on all the changes to accept/deny
-do a second round if necessary... (usually yes)
::paul.co
12 REPLIES 12
Erika Epstein
There have been a number of discussions about this especially this last year.
Essentially you have an architect's model, a structural model, and HVAC model etc. You are overlaying in 3D models similar to overlaying the 2D drawings. You are not responsible for the other disciplines, but you can check that the different systems work together as they should and need to be.
Each discipline is responsible for and makes changes and corrections to their model.
Model checking software such as Solibri and Navisworks do just this.
They overlay the models and check for collisions. You can do this visually by overlapping the models.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
::paul.co
At the following web address:
http://www.graphisoft.com/products/archicad/training_guides/
you will find free interactive training guides from Graphisoft.
One of them is called Advanced Collaboration.
From it you can find out what GS is suggesting for such scenarios.
smith74
I'm more-less confident on what we can do now, I'm just curious how others imagine an ideal solution.
::paul.co
smith74
Seems to be an interesting idea.
Do you also use Solibri or Navisworks?
Erika Epstein
I've had limited experience with Navisworks which relies on the 3D DWG format. It was bought by Autodesk a few(?) years ago.
Solibri is from Finland and uses IFC. Both have free demos on there website.
As construction firms have seen the value of these kinds of problems to identify and resolve clashes before they are built, they have pushed the design firms and the consultants to switch to 3D Virtual Building/BIM programs like Archicad. Graphisoft's previous leader Galello was instrumental in marketing to Contractors and Owners the benefits of BIM. Constructor which used to be part of Graphisoft is now VICO. There are some good webinars here on this subject on their website. You'll see Navisworks in use.Take a look at the demos and Fridays with Vico series.
3D Dwgs are 'dumb', but small in size so easy to navigate in 3D to do visual checks throughout the life of the project.
IFC files are much larger because they retain all the data about the project which you have input. IFC files allow users of many different programs share their work aka interoperability. All team members can work smart in their program of choice.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Laura Yanoviak
There are also well-written reviews available from AECbytes:
Solibri and Navisworks -- we're considering purchasing Solibri.
smith74
Great reviews, thanks Erika and Laura.
Solibri looks clever but also very complex. I hope to see some of the basic comparison features in ArchiCAD. Then I could start to negotiate with our structural company to send us back IFC files and check what they have done in ArchiCAD's native environment...
How do you solve this situation in your current practice?
Laura Yanoviak
According to the review, Solibri is "relatively easy to use."
We save the structural IFC file as a Library Object and bring it into the AC model for manual clash detection, but we model the structure in our model separately (until the current release, Revit 2010, it could not model canted columns!) -- not necessarily the entire structure, but critical areas requiring extra coordination.
smith74
"Relatively" is a very open ended declaration
