Import IFC for Archicad (Revit Construction)
hybrid
Is there a way to completely import the Structures from Revit into Archicad, when importing, I constantly have a part of the element (walls, columns, and beams) turning into a library element or a mor (depending on the setting). I want to use a Construction from Revit as a link so that the model looks like.
Is there a real way to import normally?
AMD R7 2700 3.8@GHz | 32 Gb RAM | SSD | GTX 1050Ti
1 REPLY 1
Ahmed_K
This depends on how the model is exported from revit,
if the export parameters keeps parametricity of the elements, walls, columns, etc, your IFC should be opened correctly,
if the exported elements can be converted to composite, complex profiles, they will be ok in Archicad,
Archicad 27
Windows 11 professional
