‎2010-03-20 03:21 AM
‎2010-05-26 08:50 PM
Karl wrote:1) Because AC's schedules are horrendous to use, setup, and edit.Robert wrote:WHY would you import an Excel file into a BIM model? Where would you have that data appear and how? You can freely extract data FROM ArchiCAD and INTO Excel, which is the appropriate flow of data...
Does GS know what year it is? AC13 can not import a .xls? BRILLIANT!
If you want the Excel data on a layout, Excel has the tools to select what to display and how to display it... which is why saving as a PDF from there and placing the PDF is the sensible way to get quality results.
‎2010-05-27 11:02 AM
‎2010-05-27 06:44 PM
Achille wrote:Achille,
I to want to import excel files to Archicad!
This is a feature of Minicad/Vectoworks that i always miss on Archicad. It was extremely useful when we worked with Minicad and had the ability to incorporate large spreadsheets that were given to us by mech. engineers on large industrial projects.
‎2010-05-27 07:48 PM
Erika wrote:If the information was "in" the model we wouldn't need the consultants, would we? Or are you are you suggesting we get the information from the consultant, put it in our model, and then extract the information?Achille wrote:Achille,
When you say "incorporate" do you mean something other than just placing the spreadsheet in your drawings?
Are your consultants not embedding their equipment specifications in their models?
As Karl explained, architect or consultant this data should be extruded from the model, not the other way around.
I agree, it would be nice to be able to just put the spreadsheet back on the layout without having to first convert it to a pdf, but once done it is a matter of updating the links.
‎2010-05-27 08:45 PM
‎2010-05-28 09:22 AM
Erika wrote:It would be nice to extract the data from the model, but not always possible.Achille wrote:Achille,
‎2010-05-28 09:43 AM
‎2010-05-28 12:44 PM
‎2010-05-28 04:57 PM
‎2010-06-18 06:27 PM
