Imported Autocad Blocks are Corrupted
I have a problem when i import a .DWG file which was originally made with a Electrical consultants augmented AutoCAD Version.
Any way, the symbols, which are blocks in the dwg files import strangely:
-When I import them as pure lines (translate into: 2d elements) the symbols themselves are corrupted especially circle segments (se link to similar post below)
-When I import them as library parts (translate into: Library parts) some of them are mirrored, rotated, moved around.
The blocks have "attributes" and all the trimmings, so exploding them in AutoCAD is not an option.
I did find a similar post made a couple of months back, i think its the same problem. But no one has replied to that so I'm trying again.http://archicad-talk.graphisoft.com/viewtopic.php?t=10007
This is mission critical and I dont wan't to spend a couple of days sitting the office only autocad computer redoing work in autocad, so I hope someone has some suggestion.
The Best Regards,
Lars
0 Replies 0
