Importing AutoCAD files with 3d lines (for terrain)
So we've got an auto cad file with lines that represent the terrain and it is visible in the 3D window of autocad.
How can I import this file to archicad, while keeping the lines at their level in 3d? Or is there a way to export it from autocad and make into a model?
Thank you!
Szabolcs Miko
Barry wrote:
It has been an awful long time since I have done this.
But from memory you have to open the file as a library object.
Open menu > Libraries and objects > Open object
Then change the file type to DWG so you can see it in the list.
I think this will create an object of it that you can place and possibly convert to a morph if you need to.
My memory may be failing me though and I don't have a file I can try.
You're right Barry, we only have an old article on this one, but it's still relevant: https://helpcenter.graphisoft.com/knowledgebase/25573/
Only instead of File Special, now we call the menu File/Interoperability
Szabolcs Mikó
Education Program Manager
Szabolcs Miko
Szabolcs Mikó
I always forget this.
I have kept the old menu structure in my new work environment.
Thanks for the link.
