Importing Google earth terrain model thru Sketchup
I am trying to import a Google Earth terrain model into Archicad thru Sketchup. I was able to do this just this past winter. Sketchup has since changed it's ways and requires one to own Sketchup PRO ($695.00) to have this functionality. Are there other ways to do this?
My stupid question of the day is why doesn't Archicad have this functionality built into the program? We had it once.
5 Replies 5
a little update:
I have downloaded the 30 day free trial version of Sketchup Pro. For terrain models and satellite images Sketchup is now using Digital Globe not Google Earth. This information is generated within a window inside of Sketchup as opposed to importing a KMZ file. Once I generate a SKP file I can drag the file into Archicad. When I try to import a KMZ file into Sketchup Pro it doesn’t appear. I could be doing something wrong as they still show KMZ files as an import option. I want to find out if that is still possible as Google in my situation has more current satellite imagery. I get the feeling they are blocking this functionality. Anybody else wandered down this rabbit hole?
https://www.digitalglobe.com/
latecia
Funny I was trying to do the very same thing today, the Graphisoft user guide is absolutely no help as it talks about the older versions as if they are current and that it's as simple as that, you can hardly find any reference that the interface is no longer offered, or that you are looking at the older versions of Archicad instructions. I've used the SketchUp method in the past but can find no reference on how to do it now that there is no interface between Google Earth and SketchUp.
Latecia Herzog
ArchiCad 19 & 20 Windows 7 pro
intel i7-2600 3.4GHz 8GB RAM 64-bit
dual monitors
Latecia Herzog
Myers Anderson
Windows 10 Pro
Processor: Intel Core i7-7700t CPU @ 2.9 GHz
Memory: 16 GB DDR4 RAM
Graphics: NVIDIA Quadro P3000 6.14GB GDDR5
Duel Monitors: Dell P2417H
User Since: 1999 v6.0
ArchiCAD 22 (7000 USA Full)
Katalin Borszeki
Hi All,
SketchUp does no longer have access to Google's geo data because they had a 5 year deal with Google after Trimble bought them out. Apparently, SketchUp pro still provides this data from another provider. Our recommendation here is to use SketchUp pro because there is no other way to get Google terrain model into ARCHICAD without the aid of Sketchup. Best,
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
Aaron Bourgoin
there are Grasshopper tools in Rhino that do things like this.
The results could be passed to and made available for ARCHICAD via the Rhino-Grasshopper connection.
oh wait. it's not ready yet. maybe next year.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 30 / AC29.2.1 COLLABORATE AC30.0.0 COLLABORATE
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
A major shortcoming of ArchiCAD is that we are left to rely on Sketchup! Need a library part...check sketchup. Need a terrain map....NOT EVEN GOOGLE....hey go buy Sketchup PRO. Disappointing response from Graphisoft.
