Work with external software and open exchange formats (IFC, BCF, DXF/DWG)
Importing a Lumion 11 Collada file back into Archicad 26
cheamsanzu
I have a Lumion 11 Collada file that I'd like to import back into Archicad 26 to make some changes and edit some specific materials. I lost the original project PLN but still have the Collada file of the same. Is it possible to do so?
1 REPLY 1
In Archicad, go to the FILE menu > Open > Open.
Change the file type and you will see there is a Collada file (*.dae) file type.
Give that a go.
If not you will need to save the file in Collada (if you can) to one of those file types that Archicad can open.
