Importing fonts
I have a new true type font I'd like to import, but can't seem to find out where to do it...can anyone help?
It is good to put your operating system in a signature as it is probably a different procedure. If you are on Windows you need to open your Control Panel and go to the Fonts folder and chose menu command Add New Font under File Menu. Find the font in the browser window in the bottom half of the dialogue box and it will appear in the upper box when you find a font. Select the font and make sure the tick box is selected at the bottom which says "Copy fonts to fonts folder"
Gerald Hoffman
ā€œThe simplification of anything is always sensationalā€ GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
Thanks..that worked perfectly!! Knew it would be easy once someone opened the door...
