2026-07-08 04:29 PM
Hello everyone!
We are having a issue with the Keynote function when importing an IFC-model from an external bureau (structual engineer or installer for example).
We provide them with our IFC-model, they use it to make their plan and send their IFC-model back to us.
When we import their IFC-model some of the keynotes used in our drawings go into conflict with the hotlink (see image).
According to Graphisoft, Keynotes don't get exported when exporting an IFC-model, so we don't know why is conflicts with our hotlinks.
(We have had this issue with multiple projects).
We can't find a way to exclude Keynotes when importing/exporting a IFC-model.
Does anyone know a solution to this?
Would like to hear from you!
Kind regards,
Julian Fiole
Bongers Architecten BNA
Solved! Go to Solution.
2026-07-24 10:36 PM
We have had similar experiences with keynotes and IFC files. We have determined that when we link a consultants IFC file to our project model, Archicad opens our default project template and uses that to import the IFC file. Any keynotes in the default template that are identical to the project file keynotes are then in conflict. We had to remove all keynotes from our default template to avoid the conflicts. We don't like this behavior and worry that it is going to be a problem in the future in some way we have not yet anticipated.
In spite of the immaturity of keynotes and all the adjustments to our workflow we have had to make to use them, our office is getting more proficient and experienced using keynotes and desire to keep using them. We hope that development has not stopped on them and they will continue to improve.
2026-07-09 02:30 AM
Incorrect image attached.
08:02 AM
- last edited on
2026-07-09
07:27 PM
by
Hi Barry,
Can you open/see this one?
Would like to hear your opinion on this topic!
Thanks in advance.
2026-07-09 08:39 AM
Much better, we can see that image now.
I am afraid I won't be of much help.
I don't use keynotes and I don't use IFC files either.
What happens if you click on the information button on the right hand side?
Does that shed any light on what the problem might be?
2026-07-09 09:35 AM
Ah thanks for your confirmation.
The information button on the right hand says the following:
''This keynote has a different Description than in the host file or other module.
The Description or this Keynote will not be displayed in Labels or Legends''
This is because the information/text in our Keynotes have been changed between the moment of exporting our IFC-model and importing their IFC-model.
We use Keynotes as a autotext in our detail drawings, so the information changes sometimes as the project moves on.
Therefore we would love to have a solution to our problem, because it is verry annoying.
We would love to hear from someone that is dealing with IFC and knows a lot about the export/import settings.
Julian.
2026-07-24 10:36 PM
a month ago
Hi TB,
While testing with a few projects and import settings we found this problem/solution in the template as well.
We have made contact with Graphisoft about this issue and hope to see some adjustments in the future.
Thanks for your response!
Kind regards, Julian.
