Work with external software and open exchange formats (IFC, BCF, DXF/DWG)
Imprecise translation to dwg
DianaCz
Hello,
I am trying to export my layout with a view of drawing (in millimeters) in scale 1:500 to dwg model space 1:1 in meters while preserving precise coordinates of a certain point. I adjusted my translator as shown below and placed my view on layout so that the distance of the point to layout's reference point would give me exact coordinates I am looking for. It looks like everything works just as I want, but the position of the exported dwg point differs by 0.001-0.005 m (1-5 mm) from the original coordinates. Is there any way to improve the precision of dwg export? Or maybe my method has some severe drawbacks I am not aware of?
Edit: for anyone who is interested in this topic, we started to use dwg translation from archicad view using survey point coordinates in "Match file's origin" (survey point coordinates have to be filled accordingly in project Location Settings).
3 REPLIES 3
runxel
Guru
Hardly an expert in DWG export, but what I don't get: You're scaling something back and forth and wondering about minuscle deviations? I think that's just to be expected...
Hello runxel,
Thank you for your reply. Do you happen to know how to export dwg directly from the view to be in absolute coordinates, then? I would be grateful if you could share your experience with me.
This thread might help you. Good luck!
