Interoperability: Exported Property values are different from the schedule.
Dear All,
Please see the screen shots.
The top table is the one exported from archicad.
The bottom table image is the one generated in Archicad24.
Values in column Existing Carpet Area (Area) are different.
[attachment=0]Interoperability Issue.docx[/attachment]
When the table is saved in Excel using File/ Save As command values come correct.
Is this a problem of EXCEL or ?
Kindly reply. Thanks in advance
1 REPLY 1
Minh Nguyen
Hi Anu,
Thank you very much for your question and I am very sorry for the issue!
I believe Carpet Area is not one of the default parameter, but a custom one. Could you share with us the file your are working on for further investigation? Please let me know if you'll need a secure place to upload your file.
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
