2006-10-09 08:25 PM
2006-10-11 07:31 PM
2006-10-11 08:14 PM
joshcookie wrote:Being from Montana and using ADT for CAM, my guess is that they are a log home manufacturer/builder.
Just a side question, where do you work so that everything hinges on log walls?
2006-10-11 08:43 PM
Djordje wrote:Sorry, no. I wasn't going to answer a Revit question in an ArchiCAD forum. It can be done, as others have now posted.
IMHO, not getting an answer - official or not - is a good reason NOT to switch.
2006-10-11 08:47 PM
sirduncan wrote:I haven't tried this, but I've heard IFC is the way to go. Export an IFC model from Revit, import IFC to ADT.Thomas wrote:So I'm finding. Thanks. Anyone know where I can get a difinitive answer on this issue?
- My sources tell me Revit files are NOT compatible with ADT.
2006-10-11 08:50 PM
sirduncan wrote:I would be curious to know what the production department has tried so far. ArchiCAD is certainly no CAM solution out of the box, but then neither is ADT. It seems that once the geometry is in place it shouldn't be too hard to get out the cut lists and patterns. I guess a lot depends on the details of how LHS works.
The company I work for uses ADT with HSB in the production department because it interfaces with their machines in the yard. Despite their best efforts(they say), they can't get ArchiCAD to interface with the machines. So they (the production department) can't switch to ArchiCAD.
2006-10-11 09:32 PM
Scott wrote:AC has a built in Log Feature that is fast and effective for what we are doing. Plus, if you add the Log Home Solution - you can do far more.
How is it done in AC?
Scott wrote:This was the initial response from the Revit dealer I spoke with. And this may well work, but the log issue is the other stopper for us for now.
... but I've heard IFC is the way to go.
Matthew wrote:I would be too. I was originally going to do some looking into the conversion myself, but have been a little too busy to work on it.
Matthew wrote:Come on up. (plug - is this allowed? :] ) Rocky Mountain Log Homes in Hamilton Montana. http://www.rmlh.com
I wish I had an excuse to pop up to Montana to see what you all are doing up there.
2006-10-11 10:54 PM
sirduncan wrote:No, you base the sweep geometry on the tallest log wall you will build. In the properties of the Wall Style, you add sweeps to 20 feet tall (if this is your tallest wall used as a standard wall type). The actual wall in the project will only show the sweeps to the height of the wall.
But what if I decide to make my log wall 14 courses instead of 13 - or 15 1/2? Do I have to 'edit' the wall again?
sirduncan wrote:Since you are a production home builder, you will spend some time up front creating your Template file, which will include "standard" wall types. Maybe you have predefined a 6", 8", 10" and 12" log walls. To switch sizes, highlight the wall, go to the Type Pull down, and select another size.
How about switch from an 8" log to a 10"?
sirduncan wrote:Not necessary as they are part of the defined "type". you would have to add sweeps if your "typical' wall only went to 20 feet, and for some special reason you had a 30 foot tall wall.
Completely redo the sweeps?
sirduncan wrote:Sweeps are cuttable (or not, you decide) by doors and windows. Move or delete the door, and the log wall "heals".
What about doors and windows?
sirduncan wrote:No, same as above, walls/sweeps/reveals all will "heal".
If I need to move my door over - do I have to edit the reveals?
sirduncan wrote:You have two types of walls available in Revit; System Walls and In place Family Walls. System walls are the "typical" type of wall, with two parallel faces floor to ceiling with a structural core and some assembly of components including sheathing and finishes, but can include sweeps and reveals (which is the basis for all the answers above). In Place wall Families are created by the user with extrusions, sweeps, revolves, blends, or other modeling operations. Therefore, these In Place walls can be any geometry you can think of, but each wall must be modeled. System walls with sweeps will have a "hidden" wall to place doors and windows. In Place Family walls will NOT have a hidden wall, but will still host doors/windows.
Do I have to 'hide' a 'regular' wall inside my sweep to put in doors and windows?
2006-10-12 01:03 AM
Scott wrote:As a matter of fact it helps a whole lot.
Hope that helps!
Scott wrote:Indeed. And that is just fine with me. So if I understand correctly, I setup all of my different log sizes/diameters - up to 20 feet tall each. Then they should work just like a regular wall. if I set the height to some odd number, it would show 12.37 courses - or whatever? That would be great for now.
... you will spend some time up front creating your Template file, which will include "standard" wall types.
2006-10-12 03:21 AM
sirduncan wrote:There's gotta be a way to go straight from BIM to the machines. This seems the better path than figuring out how to translate to a moribund half-BIM product. Whether the modeler is ArchiCAD or Revit this has to be the solution in the long run.
Now - about that exporting to ADT thing . . . . . . . . . . :]
2006-10-12 03:47 AM
