Achille Pavlidis
Macbook Pro and three click gesture
Hi, is there a way to use the three finger gesture in Macbook pro to work as pan command?
Mac OS 26.1 | AC 29.0.2 INT 3200 FULL
10 Replies 10
There's an add on piece of software called 'Better Touch Tool'. It offers a lot of customizability for the trackpad and magic mouse. You might be able to use it to get the desired result.
Good idea. This would be handy for occasional use of the track pad. I've been using Better Touch Tool with good results and will have to try it.
David Maudlin
Achille:
This tip was posted here by one of the developers: while using a two finger gesture will Zoom the view, holding down the Option key while using a two finger gesture will Pan the view.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I often give my machine a two finger gesture
It doesn't like it much though
Here in the states it's the one finger salute. My computer couldn't care less, heartless brute that it is.
Achille Pavlidis
here in Greece we have the five finger salute, so we beat you all!!!
A greek school friend showed me a ten fingered version accompanied by a phrase that sounded like "na fas skata". I assume the five fingered one is short hand (so to speak).
Achille Pavlidis
I would say the 10 fingered is sort of "double" the standard!
The usual frase is just "Na!" or "Orse!" but others also may apply!
here's an assortment from old movies... http://www.youtube.com/watch?v=a42-l-bb9oM
Achille Pavlidis
Has anyone used this tool to pan with archicad???
I was trying but didn't sucseed...
