I have tried all the translators and i continue to have the problem where the master layout is not showing up. Is it because it is a teamwork file, not in my workspace, i dont know? please help
Because you use the word "translators" I assume you mean that Masters don't appear when translating to ACAD -- could you please clarify? AC build/computer specs?
MacBook Pro Apple M2 Max, 96 GB of RAM AC27 US (5003) on Mac OS Ventura 13.6.2 Started on AC4.0 in 91/92/93; full-time user since AC8.1 in 2004
Make sure the layers that contain your Master elements are on in the Layout Book (I don't believe that any of the translator settings have to do with Master output).
The Layout Book has its own active Layer Combination (which is different from the Layer Combination set in the Model). Our "Layout Book Layer Combination" is simply all layers on with the exception of no-plot layers. Does this answer your question?
