Mesh Generator by Master Script
With the Mesh Generator you can easily create meshes of any kind, blobs, soft objects, free forms. With the Mesh Generator you just draw the sections, preview it in 3D and convert it into a ArchiCAD mesh.
During BETA stage for extremely low price! CHECK IT OUT!
37 REPLIES 37
The Savill Building in Windsor Park United Kingdom, made in 5 minutes with the Mesh Generator, check out the video on the website.
Mats_Knutsson
Mentor
I just wanted to test this promising tool. ...and.....it was really easy...my design suck, sorry for that...I had no clear idea what to do but I'll create a counter when I get access to controlling the thickness of the mesh.
The manual "fix" with the text file was super easy. Almost no hassle.
I'll think a little of the design before I start modelling for the next test.
Edit...forgot to attach the image and now it's gone...sorry. I'll make a new one later.
/M
AC 25 SWE Full
Mats_Knutsson
Mentor
Hi Master,
I got some time testing the lower surface and I end up with ...ah, you see it in the attachment. SEO volumes didn't overlap perfectly. Suggestion?
Looking super otherwise!
Mats
AC 25 SWE Full
ejrolon wrote:
tracyk859 is Spam
Clearly. But what is the point? Is it a bot? Why do they bother?
I would like to share an example made by a user of the Mesh Generator. Senior Architect P. Pignoli only had 20 minutes to create this beautiful design.
Check out the Mesh Generator
Mats_Knutsson
Mentor
just playing
AC 25 SWE Full
All modeled in archicad. About two hours of time (model and render)
The hypar of the cover 15 minutes more o less with mesh generator.
Uploaded with ImageShack.us
only 60 euros ????
Can this script run on Archicad 12 International ?
SALE! Mesh Generator by Master Script
With the Mesh Generator you can easily create meshes of any kind, blobs, soft objects, free forms. With the Mesh Generator you just draw the sections, preview it in 3D and convert it into a ArchiCAD mesh (see video).
Now for only € 30,- or US$ 41,-
Check this ArchiCAD talk topic, the website and the example page.
Hello can this add on work for archicad 15 ?
Also is it easy to get thickness form the new forms.
So for example if i create a interesting roof and want to make a correct section, is that possible ?
Ian
