Mesh Generator by Master Script
With the Mesh Generator you can easily create meshes of any kind, blobs, soft objects, free forms. With the Mesh Generator you just draw the sections, preview it in 3D and convert it into a ArchiCAD mesh.
During BETA stage for extremely low price! CHECK IT OUT!
37 REPLIES 37
The Mesh Generator is not an add-on but an object. It is compatible with ArchiCAD 14 and 15 and will probably continue to be compatible with higher version, because contrary to add-ons it does not need to be upgraded.
cool so its just a little object that i can plonk into my model and then control it with paremetric controls.
sounds interesting.
do you have a free test version ?
so i can play with it before i buy something,
Thanks.
Ian
There is no trial version for this, because it is just an object. But it is on sale 50% off!
Mesh Generator
stefan
Could you show how it behaves in 2D drawings?
Archicad-user since 1998
my Archicad Book
After you have completed all the steps, it is a regular ArchiCAD Mesh, with the Mesh-2D representation.
If you want something Floor Plan Display-sensitive, check out my Object Slicer.
After you finish generating the Mesh, you can turn it to an object. The Object Slicer cuts this object into pieces.
Ahmed_K
Mentor
this nice object solves a lot of archicad modeling problems , why you stopped working on it ? !! you can add a lot of possibilities and automate some actions so the workflow would be faster
Archicad 27
Windows 11 professional
Hello guys,
Was wondering if this works with ArchiCAD 18/19 on Macintosh.
can someone upload the mesh generator because i can't find it anywhere. Thanks
