Navisworks 2012 exporters update
I just downloaded the navisworks 2012 exporters update thru the Autodesk Subscription.
This supposed to make the exporter available for ArchiCAD 14, 15.
I installed it. And now when I open ArchiCAD 15, the save as option is available for .nwc (which wasn't before)
The problem is once I tried to save it as nwc, it gave me a warning message:
"Cannot write output file I/O error."
What's the reason of it?
Thanks,
David
1 Reply 1
You probably just copied the exporter plugin. It need the license info to work properly.
Content from:
\Navisworks_Exporters_2012_Multilingual\x64\en-US\NWEXPORT\root\nwexportrevit2012\nwcreate_data9\en-US
to
C:\Program Files\Graphisoft\ArchiCAD 15\Add-Ons\Import-Export\nwcreate_data9\en-US
