‎2021-08-03 06:36 PM
‎2021-08-10 01:48 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2021-08-30 11:59 AM
‎2021-09-02 02:15 PM
Thank you very much for the idea!
As a workaround, what if we temporarily set the user origin to the center of the Survey Point, then using the tracker input (and with the option above active), we can place objects based on the Survey Point coordinates. When we finish, it's easy to reset the user custom origin. Would that work for you?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
