No links in detail markers after layouts published to DWG
I am working on a job that has moved AC9, AC10 to AC11. There are 3 PLN files. One for the layouts, another for site work and a final for all the other drawings. All the auto links for the wall sections and details are self contained in each PLN file.
The problem comes when I publish our layouts in DWG format for our clients files.
In the layout file I can see the auto detail and wall section links but after checking the published DWG file the links are gone and only reference text that you see in the model/work window is shown.
My thought is that the detail/section markers are still version 9 or 10 and they don't show the linkage in the working windows like version 11 does and that is messing with the publishing.
Yet if go to change them to version 11 markers I will need to redo all the settings and reposition them as well. I know with objects you can hold down Ctrl + Alt and move the settings over to a similar object (IE Door and window settings.)
Any other ideas out there?
0 Replies 0
