4 weeks ago
I have layouts in Archicad with standardized numbers as their Layout ID, and free-text descriptions as their Layout Name.
I would like to keep the names, since they make it much easier to navigate and identify layouts in the project. However, when publishing/exporting them as DWG or PDF, I would like the filename to contain only the Layout ID, not the Layout Name.
For example:
Layout ID: A-01-001
Layout Name: Ground Floor Plan – Existing
Desired filename: A-01-001.pdf / A-01-001.dwg
Is there a way to configure Publisher to use only the Layout ID as the exported filename?
Operating system used: Mac Apple Silicon Tahoe 26.6.2
Solved! Go to Solution.
4 weeks ago
You can use autotext to rename them: https://support.graphisoft.com/hc/en-us/articles/31953101551377-Using-the-Rename-Items-function-in-A...
4 weeks ago
4 weeks ago
Thanks! Unfortunately, the link doesn't work for me?
4 weeks ago
Weird. I checked both from a private window and mobile and for me it worked.
You can maybe try and restart the browser? or just google the title of the article:
Using the 'Rename Items' function in Archicad publisher: customizing file names with autotext keywords
4 weeks ago
You need to use keywords for autotext. You can find all of them in Archicad help.
4 weeks ago
Weird, worked finally from mobile and another browser. Thanks!
