DangCad1
Publisher: Use Layout ID as exported filename
I have layouts in Archicad with standardized numbers as their Layout ID, and free-text descriptions as their Layout Name.
I would like to keep the names, since they make it much easier to navigate and identify layouts in the project. However, when publishing/exporting them as DWG or PDF, I would like the filename to contain only the Layout ID, not the Layout Name.
For example:
Layout ID: A-01-001
Layout Name: Ground Floor Plan – Existing
Desired filename: A-01-001.pdf / A-01-001.dwg
Is there a way to configure Publisher to use only the Layout ID as the exported filename?
Operating system used: Mac Apple Silicon Tahoe 26.6.2
AC 28 / Apple M4 Pro 24 GB / OS Tahoe 26.3.1
1 Solution
CosminF
You can use autotext to rename them: https://support.graphisoft.com/hc/en-us/articles/31953101551377-Using-the-Rename-Items-function-in-A...
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
5 Replies 5
CosminF
DangCad1
Thanks! Unfortunately, the link doesn't work for me?
CosminF
Weird. I checked both from a private window and mobile and for me it worked.
You can maybe try and restart the browser? or just google the title of the article:
Using the 'Rename Items' function in Archicad publisher: customizing file names with autotext keywords
Karel Landa
You need to use keywords for autotext. You can find all of them in Archicad help
From Archicad 17
MacBook Pro M1 Max
DangCad1
Weird, worked finally from mobile and another browser. Thanks!
