Opening /converting AC 11 or older version files into AC 12
Hi friends,
I searched the topics about opening older versions in new versions but i couldn't find enough information about opening AC 11 - AC 10 files in AC 12.
How can we convert old library parts into new library parts? ( windows, door names etc...)
Thanks
1 REPLY 1
Eduardo Rolon
Doing a quick search
open AC11 files in 12
opening library parts
and the most difficult recommendation because only a select few of users worldwide are able to use this most complex of commands since apparently it is more difficult than GDL programing.
Please Read,
Under Help Menu -> AC12 getting started
___
Since RTM will not work the answer to this difficult question.
Open the object and save it using AC12
and/or
Open the pln using AC12 and only load the AC12 library, AC11 migration library and your office library.
____
BTW I am being sacastic
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
