Hello famadorian,
Open Archicad Library
Search "North"
And use the ifc North
Then you have to check your ifc translator to be sure about your origin parameters
Autodesk don't use GPS coordination about an origin so there is this object for openbim collaborations
Finaly there is no reason to do a scale between revit and Archicad because a BIM model is modeling in 1:1
