Original classification visible into ifc export
We all use classifications.
Some of us are use to keep archicad classification.
Finaly we all export ifc files.
I use Solibri Model Viewer on macOS.
With Solibri I can see my BIM model by Layer, by Containment, and by Component.
I wonder if it's possible to see my BIM model by class ?
I wonder where to find which classification was used for each ifc file into Solibri Model Viewer or other viewer ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
11 Replies 11
Aaron Bourgoin
After a lot of investigation, I discovered that the disability[pearing elements disappeared because they were all crafted with Air as a material and then painted with a surface override. My translator was set to activate elements that participated in collision detection and so, they just vanished into thin air.
Air is a thing in ARCHICAD. That's the big lesson here.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.31 Mac
MacOS Tahoe 26.5
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Aaron,
Thank you for your finding! I don’t have much experience using IFC, but I guess the problem is now solved for you? Is there anything I can help you with?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
