Pro engineer to archicad 14
hi just wondering is it possible to make an object in Pro engineer then transport it to archicad 14
3 REPLIES 3
You will have to try it.
If you save a 3D DWG/DXF/DWF, 3DS or IFC format from Pro Engineer, you can try to import it and see how well it works.
I tried from pro engineer into AC14 and its very flakey to say the least. I was hoping that by now they would have managed to join engineering components to architectural. I have had this problem for years and solved it only by using 3D studio but its not a very elegant solution. Has anyone tried it with AC15 yet?
Best
Frederick
The best way I found was Pro-eng out as stl, open in blender and correct the orientation, then save as 3D-studio. Import this into AC.
Hope this helps.
F
