Procedure to Import 3D Objects
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2009-03-24 08:03 PM
‎2009-03-24
08:03 PM
My purpose is to grab the manufacturer's object and place it in my plan without having to redraw it. Also I would like to keep the object's dimensions. I just don't want to import any layers that are part of the manufacturer's object, so I don't increase my number of layers.
Please enlighten me. Thanks.
Roger
Labels:
- Labels:
Data Exchange
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-03-24 09:53 PM
‎2009-03-24
09:53 PM
Hi what formats are the models you are trying to import?
If they are 3DS or sketchup you can use the importer add-ons, however they will come in triangulated.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-03-24 10:33 PM
‎2009-03-24
10:33 PM
Usually the models that are provided by manufacturers are in .dwg or .dxf format. I am playing with Sketchup to see if I can bring them in that way.
Roger
Roger
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-03-24 10:40 PM
‎2009-03-24
10:40 PM
ok, well if you have a 3d .dxf file try opening it as an object. It will probably open up as a 3d wireframe object though.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-03-24 11:24 PM
‎2009-03-24
11:24 PM
I tried using File>Libraries and Objects>Import Blocks from DWG/DXF and I waited. Still have not seen anything turn up anywhere. I zoomed to extents in case I was looking too closely and still nothing.
I managed to get the man in wheelchair sketchup model to come in, but than I drew a little projector and saved the file in the project library and I can not get it to import. I think the Man in Wheelchair may have downloaded as a .gsm object.
This is taking too long. Time to go home and mess with it over food.
Thanks for your input.
Roger
Roger
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-03-24 11:29 PM
‎2009-03-24
11:29 PM
for the .dxf go file>libraries&objects>open object then select it and it will open it as an object. But it will just be a wire frame model.
What model are you trying to convert? someone may already have one.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-03-25 12:39 AM
‎2009-03-25
12:39 AM
I see that two of the .dwg files are 2D. I brought them in and drew lines on them in 2D and created a .mod file for a Bradley sink system. When I was drawing it looked like I was following the top view of a 3D model. No such luck. Of course they are lines only. I will try it again with a cabinet model.
I still have not found how to get a Sketchup model to import.
Thanks again for your input.
Roger
Roger
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-03-25 01:04 AM
‎2009-03-25
01:04 AM
rhendrickson wrote:You need to download the sketchup importer add on, click on goodies in the help menu.
It will triangulate everything tho.
