Quantification MEP?
I have been trying to make the quantification for mep objects, I can make a list in which shows me the number of pipes in one story, but I cant get to show me the diameter of each pipe/tee/duct/ (or (eg. 3/4" or 1 1/2" ), and also cant get listed the lenght of the pipe (eg. 4 meters of pipe).
I have try by IFC properties, but it only shows me roof, wall, beams, etc properties.
Does Archicad can make quantification of MEP objects in detail ? Or do I need another software or plug-in?
If I need another software can you please recommend me one? Since in my work I have been asked to make this quantification.
Thank you all!
1 Reply 1
David Maudlin
anshesita:
The information is there, but you will need to dive further into the objects' parameters for the Interactive Schedule. For example, for the Pipe Straight 19 object, under Scheme Settings > Fields, click the arrow next to the Add button, and select Add Object Parameters. Navigate to the MEP Library 19 > 23 HVAC 19 > 23 20 00 HVAC Piping and Pumps 19 > 23 21 13 Hydronic Piping 19 > Pipe Straight 19. You will see a list of available parameters to list, for the Length select Length (MEP_StraightLength), for the diameter you can select Nominal Size (ConNominalWidth_1) or Main 1 Connection Out... (ConWidth_1). Once these have been added to your schedule, you and a sum for the lengths if desired. It helps to look at an Object's parameters to see which parameters you need before going to the IS (Interactive Schedule).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
