Quick calculations_surfaces and volumes
Tring to find the quickest way to have a quick take off of volumes and surfaces - by making a mass study by story.
Do i
[list=]use the morph too? [list=]define heights and stories as normal then use will the fill tool to give me a schedule of surfaces. The volumes i am assuming I could take from the storey's created ?
thX
SW
1 Reply 1
Piotr
Hi
You can model whole building using only one morph element. No need to use fill tool for areas. Volume can be calculated following stories heights.
10x10x10m morph cube and 3,10m story height are used in the above example.
Regards
