Josh Verran
Quick method to modify mulitple Layer Combos at once
Is there any way to quickly turn new layers on and unlock for existing layer combos, rather than having to manually turn the eye and lock on next to each layer combo name?
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
1 Solution
sinceV6
Hi.
You can use the Attribute Manager to change several layer combos at once.
Best regards
Go to post
1 Reply 1
sinceV6
Hi.
Best regards
