matthewjj
Renovation Filter + External DWG = CRASH
Graphisoft,
Seriously, when are you going to fix this!?
Whenever Renovation Filter is set to override and there is a DWG placed as an External Drawing it causes a crash.
This was first mentioned here in the forum in September:
http://archicad-talk.graphisoft.com/viewtopic.php?t=37651&postdays=0&postorder=desc&highlight=renova...
Also mentioned here in October:
http://archicad-talk.graphisoft.com/viewtopic.php?p=198511&highlight=dwg+renovation+filter#198511
matt johnson
archicad since 2004
imac 27, 4.2 GHz Intel i7, 16 GB RAM, radeon 575 4 GB, macOS 10.14.6
imac, 4.0ghz i7, 16gb ram, Radeon M9 390 2GB, OS X El Capitan
3 Replies 3
owen
Yep affects both DWG + PMK .. this is a real 'show-stopper'
owen wrote:
We can also confirm this bug as well for both DWG & PMK when placed in a floor plan view - if any renovation filter is set to Override there is 100% a crash on placement. It is also very likely to crash once a drawing has been placed (i.e without an override active) but then changing to a filter with an override.
With no overrides the same PMK's and DWG's were placed with zero crashes.
Tested in several locations, on multiple machines, both Teamwork and PLN.
This is really a killer bug which needs to be fixed ASAP
cheers,
owen
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
David Shorter
Hi Guys
Tried to reproduce is but it works fine for me
Does it need all the filters to be set to override?
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
matthewjj
This has been fixed in Build 3602.
matt johnson
archicad since 2004
