Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
!Restored: Cinema 4D plugins for AC11
anybody can tell me where can i obtain the plugins for Cinema 4D 10.5 for work with Archicad 11 ? also where is the correct place (i mean folders) to put these plugins ?
thank you in advance
12 REPLIES 12
I've downloaded them from here
http://www.graphisoft.com/products/archicad/solutions/cinema4d_download.html
but I couldn't get them to work. When I go to "Create New Object With Cinema 4D" (from 3D window), C4D is launched, but no data exchange is made (and the "Plugins" menu doesn't contain any ArchiCAD reference).
Maybe someone else knows something about this?
Cheers.
Adrian Tudoreanu
Have you tried selecting an object within the perspective window and then 'edit object in c4d' from the plug-in selection. It works for me.
I tried opening c4d from the floor plan and also got nothing!!
Also there is a sperate plug-in for the cinima 4d side of things... have you installed both the c4d plug and the archicad plug?
owen
The instructions for installation on the Graphisoft site are wrong.
Step 3 should read:
3. Download and uncompress the Cinema 4D 10 plug-in to your MAXON\CINEMA 4D R10\plugins folder
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Thanks for the heads up, we corrected it.
Gergely Kmethy
VP, Customer Success, Graphisoft
Just one question: I saw on maxon website that you can save inside ArchiCAD cinema file(save as). A've instaled plugin below, but, i don't have that option?! But i have option to edit something in cinema.
owen
Are you refering to this?:
http://www.maxon.net/pages/solutions/archicad/archicad_e.html
This is talking about the Material Exchange plugin, which is different to the Maxonform plugin you seem to be talking about (it gives option to 'Send back to ArchiCAD')
The Material Exchanger is a 1-way plugin to map materials applied in Cinema to ArchiCAD materials. Using this you can simply export updated geometry out of ArchiCAD and the plugin does all the time-consuming work of re-applying the materials (near instantaneously). There is no functionality to send anything back to ArchiCAD.
As far as I am aware you cannot download this plugin from the Maxon site - only updates. You need the original plugin installer which came on the Cinema 4D Architecture Bundle CD.
Maxonform enables you to edit/create new elements within Cinema4D and send them back to ArchiCAD as a GDL object. It is activated from within ArchiCAD. There are two plugins you need to install - one for each application. It sounds like you have only installed the Cinema part.
Maxonform is not supported anywhere on the Maxon site - refer to the links above for Graphisofts instructions.
cheers,
Owen Sharp
this is what i had in mind:
http://www.maxon.net/pages/solutions/archicad/images/exchange.jpg
there is even a video about that, i'll find it latter.
owen
WhiteMan wrote:
...But i have option to edit something in cinema.
OK this is what had me confused - is this option appearing in ArchiCAD? Sounds like Maxonform, the Exchange plugin only adds a file format (Cinema4D - i.e .AC4D) to the Save As dialog.
The Exchange plugin installs to Cinema4D and then you need to move a couple of files in places there into your ArchiCAD Add-Ons folder. They will be in a folder like:
/Applications/MAXON/CINEMA 4D R10/Exchange Plugins/ArchiCAD 10/MacIntel
HTH
cheers,
Owen Sharp
