AntonGrassl
Beginner
ArchiCAD to Cinema 4D Plugin problem
I installed the Cinema 4D Plugin and everything seems to work! Only when I want to change the export options from Class to surface the Plugin does not appear in Interoperability neither in planning extras. My Archicad and Plugin versions are the latest and both German.
Thanks for the help
Can you manually add the commands to the menus in the Work Environment settings?
I know with other add-ons (i.e. goodies), the menu commands are not added when you install the goodies after you have already run Archicad 26, but you can manually add them.
