Revit Library Part Converter
Scott Bulmer
Greetings, I have not seen this topic and apologize if it has already been discussed.
Is there any converter available to allow conversions of the over abundance of Revit library parts provided by manufacturers?
Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
1 REPLY 1
There is no converter and there is unlikely to be, the RVT file format is not a published format and would need to be reverse engineered. The file format is also in a constant state of change with each version (including point versions of revit) changing the data structure slightly meaning that any 3rd part non-authorised converters would break.
