Rhino - Archicad import
I have Archicad 17 but really need to import Rhino objects...is this possible?
If I download a trial version of archicad 20/21 can I use the Rhino plug in and then down save for my Archicad 17 use?
Can an archicad 21 file be downsaved to archicad 17?
10 Replies 10
You should also consider the capabilities of the new Grasshopper-ARCHICAD connection which can use geometry in Rhino based on which it can create elements in ARCHICAD.
It may be able to speed up your Rhino-ARCHICAD workflow.
