SCHEDULES
Opened my door schedule today, started making changes in several columns.
one being leaf thickness. Changed several doors thickness, no problem.
Went for coffee, came back and continued to change several doors thickness but the schedule would not take the info.
Went to ones I had already done....now couldn't change those!! Checked all fields that are editable (blue only editable) and could not change any!
Saved file, closed project. Opened back up......cant change a thing in the scheule.
Opened an Exterior door schedule......cant change any column item there.
Any ideas?
1 Reply 1
Check that the layer that the doors (walls) are in is currently visible and unlocked.
if the layer is off or locked they will still appear in the schedule, but won't be editable.
You will find the select in 2D & 3D icons at the top will also be greyed out when you select a door in the schedule.
