Schedule Mirrored (Handed) Objects
Hi all,
Seems a basic requirement, but has anyone been able to schedule whether an object is mirrored or not.
I am going a bit mad trying to work it out. I cant seems to even create a custom parameter to show this, as it gets greyed out when I try to bring it as an object parameter in the schedule.
Matt Balaam
I just created a quick object with a single parameter called iAmMirrored (Boolean) and put the following in the Master Script:
parameters iAmMirrored = SYMB_MIRRORED
I can then add the parameter as both a criteria and as a display field. The only parameters that are greyed out for me are heading parameters.
I can't see anything in the standard fields that displays the mirrored status. Could be good to add this as a wish though as I can see times when it would be useful.
AC29 AUS | Windows 11 | Intel Core i7-12700 @ 2.1GHz | 32GB RAM | NVidia T1000
Yes thanks, did realise it was because I got lazy by not adding a heading
