Sketchup to Archicad 11 Mac
archislave
Is there an exporter from Sketchup to Archicad 11 Mac?
Thanks!
Archislave
archicad 26.0 US, M2 Macbook Air
7 REPLIES 7
No. 😞
If you have SketchUp Pro, export to 3DS and then use the 3DS Import Goodie to convert to a GDL object.
Or, do the conversion in Windows. 😞
One of the forum moderators
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
does the goodie work on a mac? It doesn't seem to, or did I make the mistake of following the directions. I installed the add-on, the add-on manager shows it loaded. But the import menu is not found in the location the directions say it is? File->File special-> import 3ds. Any light on this?
FOUND IT! Why didn't the directions say it was in design->design extras
It would make more sense putting it where the directions say it is, in the import menu
oh well.
aahatimo
so would it be possible to do the opposite to get ac 11 model to sketchup via export 3ds?
still trying to figure out an energy modeling solution and there are a few that link to su.
thanks!
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
Chazz
One lovely addition in Leopard is full menu search. Very handy for learning new software or dinking around with the menu structure in AC. It even puts a little animated arrow next to the command you're hunting for. Upgrade now!!
Nattering nabob of negativism
rm
Chazz,
Do you know if this works on AC 12 on the Mac. I used the help menu, nothing comes up under .3ds. I can't seem to find the "goodies" folder on the install disk either.
Any ideas?
Robert Mariani
MARIANI design studio, PLLC
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
Chazz
rm wrote:
Chazz,
Any ideas?
Menu search works on ALL apps regardless of vintage. Goodies are not on the disks but must be downloaded from GS. Look under the help menu for the direct link (this question is asked frequently and you find numerous recent references if you do a search here). Good luck.
