2021-02-02 03:23 AM
2024-04-03 10:37 AM
Just a sidenote here, that I was not aware of, is that the field "Hotlink and element ID" is not editable in schedules, whereas "Element ID" is. I came here because I could not figure out why the IDs could not be edited from the schedule, but eventually figured it out. It doesn't seem like this is the exact issue for OP, but a thing to look for is whether the field is blue or black in the Scheme settings. If the field is blue it's editable and if it's black it's uneditable. In most cases "Element ID" does the trick, but in the template I'm working with the window list schedule was set to "Hotlink and element ID".
I really wish Archicad was a bit more informative in terms of the UI giving feedback on why certain things are locked, uneditable etc. I quite often find myself in situations where something just randomly will not work and having to test ten different settings to find the underlying cause.
a month ago
Still having the same problem in ArchiCAD 27 6010: unlocking all layers or blue/black fields in the schedule settings seem to make no difference.
It seems the only way to get an editable text field in a schedule—for a (e.g. window) object—is if the icon to the left of the field name is a mouse pointer, rather than "Abc".
a month ago
If you select that window in plan, can you edit the same "ABC' text field in the object settings?
If so then you should be able to edit it in the schedule.
But make sure you open the schedule from the Project Map list (that way you will have the same settings (layers) as you have in plan).
Or if you open from the View Map list, you must ensure that the layer combination is not "Custom" and that the layer the windows (walls) are in is visible and unlocked.
