T pipework in Archicad
The T connection for pipework in Archicad defaults to a horizontal direction where it looks like this in Floor Plan _l_. I need to know how to rotate it in the vertical direction that looks like this in Elevation
l
l
David Maudlin
shockwaves88:
For the Pipe Tee 15 pipe tee, go to Parameters > Rotation around "Y" Axis and change the value to 90˚.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
You can also rotate them in 3D by using the dynamic hotspot between the center point and the branch node.
