Exporting DWG file from AC15
Hey,
I`m trying to export DWG file from AC15 and I can`t enter more than 3 numbers behind comma for custom DWG Drawing Unit value in DXF-DWG Translation Setup window I´m trying to enter 0,005, but it always rounds the value up to 0,01.
Any suggestions?
Thanks
5 Replies 5
I just checked and it does seem to be limited to displaying two digits to the right of the comma/decimal point. I'm not sure if this is just a rounding of the displayed value or if it's actually rounding up the stored value. Why do you need a drawing unit of 5/1000's of a mm? Seems really small.
Thank you for your reply.
It rounds up the stored value aswell. I need 5/1000 mm drawing unit for exporting drawing from ArchiCad to AutoCad model space in 1:200 scale.
If I understand you correctly, then I don't think this setting has anything to do with that.
This would shrink you model in AutoCAD to 1/200th its size in ArchiCAD.
If a drawing unit is 1 meter in ArchiCAD you should set it to 1000 millimeters in the translator.
So if a 300 millimeter wall is 0.3 units in the Tracker in ArchiCAD, then your unit in ArchiCAD is 1 meter, and you should set it to 1000 millimeters in the translator.
If a 300 millimeter wall is 300 units in the Tracker in ArchiCAD, then your unit in ArchiCAD is 1 millimeter, and you should set it to 1 millimeter in the translator.
Thanks for your reply!
I`m trying to publish my layouts from ArchiCad Publisher Sets to AutoCad Model Space.
So, if I have my layout in ArchiCad in 1:100, I set the Drawing Unit to 0,01, then the drawing in AutoCad Model Space is 1:1. When I have my layout in ArchiCad 1:20; I set the Drawing Unit 0,05 etc. It works perfectly to scale 1:100, but further from there I have to set Drawing Unit smaller than 0,01 and then I get stuck, because I can`t insert number with three digits after comma.
So in case the minimum you can set in the Translation Setup Dialog is 0.01, then maybe there is another way.
What happens when you have a 1:100 scale View that you placed as a Drawing on a Layout, then select the Drawing and in the Drawing Settings Dialog change the Magnification factor to 50%, so the Drawing Scale becomes 1:200 (the Original Scale is still 1:100)?
Then set 0.01 in the Translator and try to export that way. Does it then give you the desired result?
