The Revit Wishlist
I have been getting a little tired of hearing how great Revit is and how much ArchiCAD sucks (or is falling behind, or failing to stay ahead, or whatever). So I decided to have a little fun.
Don't get me wrong, Revit is a good program with a lot of nice features. I have enjoyed using it on a few projects now and look forward to getting familiar with more of its subtleties and advanced features. And of course if GS stands still, or if it is perceived that they are falling behind, they will lose in the marketplace.
So I have undertaken a completely biased and unfair comparison of the two programs (since it is based on a Revit wishlist and not a feature list) to make the point that ArchiCAD does have a lot of strengths and features that Revit does not. It would be interesting to do a more comprehensive comparison (like using an ArchiCAD wishlist) but I don't have the time right now.
Apologies to Wes. I hope you don't mind me "borrowing" the list. I grabbed it from the Augi forum (it's publicly posted with no copyright notice so I can't see any harm in it) and have added my own inline comments. My knowledge of Revit is still somewhat limited so I may be a bit off on some of the finer points, but I have tried to be as accurate and objective as I can (while still having a little fun with it). And Wes, if you can add some more knowledgeable feedback about anything I have misunderstood I will be most appreciative.
- Allow shared coordinates to be used in defining heights ot point entities that define the toposurface... points only use project coordinates at this time
...We may not have the terrain tools as such but the mesh tool can do this
- Improved sloping slab / roof modeling tools (specify slope by three spot elevations)
...Sloping slabs would be nice, but we do have this for roofs.
- Allows slopes in pad objects
...I guess we would need pad objects first (library parts could do it).
- Sloping walls -- angle of slope as instance parameter (not just skinned on mass objects)
...We've got this and then some.
- Create workplane by clicking 3 points in model (sim to AutoCAD create UCS by 3 points)
...We don't need no stinking workplanes.
- Create named reference plane by selecting face of object (ref plane aligned to object face)
...I'm not sure about this one. I don't recall using these in Revit. EDIT: I just checked and realize that I've been using reference planes all along and either didn't know or didn't remember what they are called. There is much about them I still don't understand so I am still not able to comment on this one.
- Allow system families to be placed in user-defined subcategories
...That would be like layers only less flexible. Also like Classcodes which I truly, deeply wish we had.
- Allow windows/doors (but esp. windows) to be tangential to the wall when "Vertical only" is unchecked in the family. This is a huge problem for non-vertical walls where the user wants the windows to be coplanar with the wall
...We have it now.
- Allow 3D snapping of model lines and/or reference lines to allow us to escape workplane hell
...We've got this one too (and no workplane hell).
- Improved/more site modeling tools (road design, etc.)
...Yes, well, we can wish for this one too. I'll have to compare ArchiTerra 3 to the Revit tools some time. EDIT: Well I just took a quick look at the terrain tools and , unless I'm missing something, I would prefer to model terrain with the mesh tool. ArchiTerra definitelyhas functions that are lacking in Revit.
- Improved stair modeling tools and ability to join geometry with floors (e.g. monolithic concrete stairs)
...Yes, well, that too.
- Ability to customise elevation tags like you can with section tags
...All tags in AC are customizable and far more so than in Revit.
- Ability to categorize interior and exterior elevations separately and control their tags' visibility separately as well
...There are all sorts of ways we are ahead on this one.
- Transparent filled regions (allow % transparency as overlay or underlay in views)
...We have this too.
- Ability to add views (sections, elevations) while working on an in-place family
...I'm not sure what this request is about.
- Ability to resequence numbering in schedules when objects are added or removed
...We can do this manually in the IS. I haven't done schedules in Revit so I'm not sure how this compares.
- Area tool (suggested to have it built into the measure tool)
...We have this in fills, zones, and of course the measure tool.
- Ability to vary lineweights by distance from cut plane in section/elevation
...We have this partially in the distant area settings
- Camera location icon for plans
...We've had this forever
- Greater control over wall visibility in views: cores only, cores + everything else
...Well...
- non-rectangular boundaries for viewports (it's like deja vu all over again )
...This was introduced in PM2.0 as I recall
- Viewports to be "snapable" for fast, precise layout
...We've had this forever too.
- Either remove limitations of detail views for floor plans, or allow for more floor plan callout types
...We have a similar wish for live enlarged plan views.
- More control of revision schedule: direction (bottom to top), designations (not just numbers only), and allow revisions to list even if revision bubbles aren't displayed
...Well, if we had a revision schedule, we could wish for improvements.
- Report number of objects selected
...We have this live in the Find & Select and in detail in the modal Edit Selection Set dialog
- Ability to tag legend objects in legend views
...I'm not sure what this is for.
- Ability to print multi-page PDFs rather than having print/name each page manually (granted if you use PDF Factory -- or the free PDF Creator from PDF Forge)
...We have PDF capabilities way beyond Revit. As far as I can tell there is no PDF import at all.
- Allow true colour presentation option for shaded / shadowed orthogonal views (plan / elevation)
...We have this in elevations anyway. Not hard to fake it in plan by referencing a 3D view.
- Allow rescaling of hatch patterns without finding and reimporting the .PAT file
...This has always been possible in the File Types dialog. We can even rescale instances since 11 came out.
- Allow calculated values in tags (e.g. show room occupancy or corridor loading)
...Zone stamps can be easily customized to do occupancy. Accumulating corridor loading is still manual.
- Allow calculated values to control color schemes (e.g. show areas over/under building space program)
...I'm not sure what this means.
- Color fill legends should not be cut off by the crop region
...We don't have this problem.
- Allow gradient fills
...Yup, we've got these too.
- Coarse scale fills should permit a view override per category so that all walls, floors, roofs, etc can have the same coarse scale appearance in plans and sections
...We can do this in a variety of ways. View Options, Pen Settings, etc.
- Linework tool should be allowed to work on linework from linked Revit files (to remove lines between linked elements if no line would exist when the design is constructed)
...We don't need this since ArchiCAD does a proper job cleaning up the drawings.
Performance
- Double-click to edit sketch based objects rather than rolling up to the 'Edit' button
...We don't need this since we can easily edit the items (such as floors & roofs) in place without having to go into Sketch mode.
- Revamped UI: varies from requests for basic updates to inclusion of VIZ-like behaviour to commonly-used tools to modeless properties dialog box
...Revit has a long way to go to approach both the capabilities and the complexity (complifications?) of the ArchiCAD interface. If GS could really put a priority on clean-up and consistency, not only would we all be thrilled, but it would be much more obvious how far ahead ArchiCAD is in this respect
- Accurender 3 needs to be updated to a newer rendering engine
...We know how this feels. I haven't done much rendering in Revit but I understand that it is no better and perhaps worse than AC in this regard. EDIT: Mental Ray now in Revit 2009 - I don't know how this stacks up to LightWorks in AC
- Improve display system - make objects display as they do in Inventor (clear and rapid display of objects)
...I don't know Inventor, but the performance and display quality of Revit definitely lags behind ArchiCAD
- Allow double-click or right-click to edit and finish editing objects (e.g. floors)
...Again we don't have the onerous Sketch mode and so don't need this.
- Allow users to select point of rotation rather than moving icon from center of selected objects
...We have this along with the rest of the much quicker and more facile edit functions in AC.
- Auto-hiding/roll-up of portions of the UI (Project Browser, Design Bar) to facilitate more screen space
...Both programs need a face lift. At least it is possible to customize AC.
- Full screen mode
...I thought Revit had this. They must mean something different than I am thinking.
- Support for dual monitors
...AC supports as many monitors as you care to attach
- More keyboard support for commands (e.g. various line tools during detail line command)
...Of course we can customize this to our hearts' content - with a few exceptions.
- Editing request pop-up for users who need to relinquish objects
...Hard to compare, but this sounds like it could be a cool Teamwork function. Not high on the list as far as I'm concerned though.
- Select all instances: per view or per project
...This would make Revit's selection tools only slightly less pathetic by comparison to ArchiCAD.
- Make family list pull-down (Type Selector) wider, or at least appear in a tool tip: long family names are getting cut off
...Most of the field length issues have been sorted out in ArchiCAD
- Customized pallettes for storing and placing commonly used components
...Favorites, Modules, Eyedropper & Syringe tools
- "Create Similar" command should mimic all properties of the object selected (only partially mimics properties at this time)
...I still haven't got the hang of this tool in Revit. It sure is a long way from the Eyedropper & Syringe tools
- Let Tape Measure tool work in 3D
...We've got this too. It would be even more useful in Revit if you could snap to points and edges, and constrain directions as well as we can in AC.
- Option to have crosshairs as the cursor
...I'm not sure about this. If they mean full window crosshairs, well I guess I would just turn them off.
- Let Revit access the power of high-end video cards
...ArchiCAD flies on a Quadro. It's not that bad on a GeForce either. I'll try to compare the two some time if I get a chance.
46 REPLIES 46
LOL....when I was reading the "Wish List" I was wondering how old it was....
As a Revit User....and an ArchiCAD user I bring up quite often at Revit events..."Well ArchiCAD can do it!"
Lately though I have been using ArchiCAD more often, and I finally got 12...big upgrade from 8.1...But I find myself trying to do Revit commands in Archicad and vice versa for Revit....
Anyway, thanks for the laugh....
I was just sent the new features pdf for Revit 2010, looks like Autodesk has been quite busy. Has anyone else seen it? They've also updated the entire interface. I will try and upload it.
It would be nice if you could get the average Revit user to think so. Opinion on the new Ribbon is quite mixed, and the new form-making tools for building massing benefit a thin slice of the architectural market, amazing as they are. Many Revit users are furious that the UI was switched while long-standing wishes weren't addressed. The Ribbon takes up a little less space on regular monitors, and more on widescreen or dual monitors. The jury's out as to whether Ribbonization even makes sense for Revit at all.
Of more practical use is the switch to DirectX, which will hopefully get Reviteers out of the hole with respect to OpenGL compatibility. OGL compatibility, while never a problem with us, has been quite trying for many users, particularly nVidia users. Revit 2009 was about 1/3 slower than 2008 in display performance, and hopefully 2010 will bring us back to at least equal to 2008's display performance.
There are also significant enhancements to the API, so the programming crowd will have a field day with all the new aspects of Revit's underpinnings that have been exposed.
The new UI probably makes Revit easier to learn, but we don't know if it will help or hurt existing users.
My stand on the new release: speed is everything, so I'm hoping I'll give the release version a solid passing grade on this item. For myself I'm slightly negative w.r.t. the new UI, but I do recognize it will make Revit easier for newbies, and most of them are 😉
i see. yes it will be interesting to actually try it out with the new interface. I think for me (an ArchiCAD user) it would make the learning curve easier.
It probably will make Revit easier for you to learn. The old UI was efficient but so unique that its ease of use was lost on people. The old UI worked really well, frankly, though as I taught it to new users it took several weeks before some people really got around in the UI. I suppose the new Ribbon makes Revit less daunting.
Miquel Garcia
This sounds amazingly familiar for AC users…
Miquel
Capella & Garcia Arquitectura
AC18 - AC21, iMac 27" 3.1 Ghz Intel Core i7, 16GB Ram, OSX 10.13.1
metanoia wrote:
..... and the new form-making tools for building massing benefit a thin slice of the architectural market....
Boy, you'd be surprised how large that market is. It just happens to be so that that market never choices AC or Revit because of the complete absence of proper modelling tools. This creates an illusion that only MR Gehry needs these tools and the rest of the world is stuck doing boxy eye soaring architecture. At the same token, the Rhino market doesn't care about a good text editor or the ability to make custom elevation tags.
That said, the coming years are going to be very interesting for AC and Revit. After hearing for years that Revit needs better modelling tools, Autodesk surely must feel misled that when push comes to shoves, no one really wants does tools. It's questionable if Revit will respond in the future on other wishes, knowing that it wouldn't be appreciated anyhow. AC on other hand is learning from the mistake of Autodesk and might postpone the enhancements of modelling tools or a new UI.
At the end, either Autodesk will drop Revit as only a small percentage is going to upgrade this year. (not enough budged to bring out a new release) or it will turn into an high end accounting software for architects who thrive on the nitty-gritty process of construction and documentation.
We'll all have to wait and see if AC will follow the footsteps of Autodesk
TMA_80
hi!
from what i've understood, the main complaint about the new modeling ability was the fact that it wasn't extended to the family creation and limited to the massing tool...
AC12_27 |Win11_64bit|
owen
TMA_80 wrote:
hi!
Not making excuses for anyone but Autodesk are not alone in this respect ... 'New Features' in AC are frequently unfinished nor utilized to their fullest throughout the program (Profiled walls not curving, Complex Profiles still being unavailable to GDL scripts, etc)
Never quite finishing new features for a software release is an unfortunate reality that seems particularly prevalent in AEC applications. Just enough to get the upgrade with more left for next time. Graphisofts brief dabble with the 12 month upgrade cycle certainly did not help things .. but fortunately they seem to have seen the error of their ways. Who knows what AC13 will bring ... maybe just unrealized/unrealistic expectations
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
blobmeister wrote:
Boy, you'd be surprised how large that market is. ... After hearing for years that Revit needs better modelling tools, Autodesk surely must feel misled that when push comes to shoves, no one really wants does tools... At the end, either Autodesk will drop Revit as only a small percentage is going to upgrade this year. (not enough budged to bring out a new release) or it will turn into an high end accounting software for architects who thrive on the nitty-gritty process of construction and documentation.
Autodesk has metrics on how users use the software, and they are in discussions with major architectural firms that are using the software seriously. The move to the Ribbon was not done without thought to users' response; a lot of thought and effort went into it. Likewise, the modeling tools (which I again maintain are needed by a few rather than the many) help to make Revit useful for marquee architecture; so they are still interesting, if not required by a majority of architectural firms.
To say that Autodesk would drop Revit would make a good April Fools' joke -- this is their main AEC platform moving forward. I think what we're seeing is that 2010 does more for new users than existing ones 😉 So I expect it to sell into new markets, and possibly alienate some existing users.
