Uniclass2015_Jan2023.2.xml
BrentMatthew
Hello All,
Is it just me or is the 'Uniclass2015_Jan2023.2.xml' file download (https://graphisoft.com/downloads/archicad/BIM_Data) missing the 'Zz CAD' table?
Brent Matthew
Construction Modeler
BIMSOLL
i7-4930K Dual 3.4 GHz 32 GB RAM
NVidia Quadro K4000
SSD+HDD, Win7-64 ENG
AC25 (64-bit, latest build)
6 REPLIES 6
Miha_M
It's not just you and it's not just the Zz CAD table missing:
I guess some tables have been left out as they are not directly related to Archicad (output) capabilities.
| Archicad 4.55 - 27
Thank you Miha_M for your response.
This seems strange as these were included in previous versions, but you may be correct as these may be purely for exporting 3D elements only.
I tried to classify a Grid Line but not sure which table to use.
Brent Matthew
BIMSOLL
NVidia Quadro K4000
Miha_M
I'm not sure how this works with UniClass, but the Grid elements are converted to IfcGridAxis if they are included in export to IFC, even if you assign them to any unrelated classification position.
But you could also tweak the UniClass xml and add the Zz table part with Zz_35_40_80, which you have been probably looking for.
| Archicad 4.55 - 27
DGSketcher
Legend
A Uniclass searchable resource is available here if you need to look for anything...
https://uniclass.thenbs.com/
I regularly access it for my Layers.
Thanks Miha_M,
I will look into this exported IFC classification some more and do some tests.
Thank you
Brent Matthew
BIMSOLL
NVidia Quadro K4000
Hello DGSketcher,
Thanks, I use that website almost daily.
Thanks again!
Brent Matthew
BIMSOLL
NVidia Quadro K4000
